My guess is that the lower bolt was design for a front derailleur. My friend has a 2018 Epic HT and his front dee is mounted to the lower bottle cage mount bolt.I am planning to put a bottle cage on the seat tube on my new Epic. I noticed that there is currently some kind of spacer, only on the top bolt. What's this for and do I need it?
Side question: Why the heck do my attached pictures display rotated? When I open them up on my computer, they are correct. How do I get them to rotate so they are in the correct orientation when posting?
That doesn't explain the spacer on the upper bolt. Does your friend's Epic have the same spacer? Does he have a bottle cage on the seat tube?My guess is that the lower bolt was design for a front derailleur. My friend has a 2018 Epic HT and his front dee is mounted to the lower bottle cage mount bolt.
I thought it was self-explanatory. The spacer on the upper bolt is to allow the rider to still be able to mount a bottle cage on top of the front dee's mount. No, he does not have a bottle cage ok his seat tube also it is available if he wishes to use it.That doesn't explain the spacer on the upper bolt. Does your friend's Epic have the same spacer? Does he have a bottle cage on the seat tube?
I think you mean 1x, but yes you are correct. I figured that out after mounting the cage without the spacer, but the suspension linkage then contacts the bottle when compressing. The spacer gives the bottle enough clearance when hitting the bottom of the suspension travel.These bikes are designed as single speed only. The spacer is to slightly angle the bottle cage so you can fit a larger bottle in the cage. I have a medium and can fit a 750ml Fly Elite bottle in there without the spacer. A standard Elite bottle like a Corsa is a little bit too tall. If I fitted the spacer the 750ml Corsa would fit
whoops. Yes I did. Single ring up frontI think you mean 1x, but yes you are correct. View attachment 1253051
Hi,
I have the same bike and also wondered that. It is mentioned in the user-manual tho' - its a spacer to angle the bottle cage slightly forward to help clear the suspension link when you're using a large bottle.
Yes, but the front dee on my friend's epic ht has it being mounted to the bottle cage bolt and what appears to be a clamp on the seat tube. I believe it's a new direct mount front dee design for (certain) frames that have been design for 1x to go 2x.These bikes are designed as single speed only. The spacer is to slightly angle the bottle cage so you can fit a larger bottle in the cage. I have a medium and can fit a 750ml Fly Elite bottle in there without the spacer. A standard Elite bottle like a Corsa is a little bit too tall. If I fitted the spacer the 750ml Corsa would fit
