1 - 12 of 12 Posts
Frame - Foes DHS Mono 2:1 10" travel powdercoated Pearl White
Rear shock - Curnutt w/ dual Ti Spring
Fork - BOS Idylle Pro
Handlebars - FSA Gravity Light 800mm
Stem - Syncros Direct mount (replacing with Straitline Direct Mount as soon as TBSM stocks them...hurry up boys!)
Headset - Chris King Ano Red
Grips - Gold ODI
Saddle - I-Fly
Seatpost - I-Beam
Front brake - 09 Saint
Rear brake - 09 Saint
Cranks - 08 Saints (replacing with 09 Saints)
Chainguide - Custom Foes MRP Carbon
Chain - Sram PC991
Pedals - Straitline
Rear derailleur - 09 Saint
Rear shifter - 09 Saint
Cassette - Sram PG 970 Dh 11-26
Front hub - Hadley
Rear hub - Custom Foes 160mm by Hadley
Front rim - Mavic 823
Rear rim - Mavic 823
Spokes/nipples - DT Competition spokes, anodised red alloy nipples with black plastic valve caps
Tyres - Minion UST(front) High Roller UST (rear)
Discussion Starter · #8 ·
sorry for not responding...i almost forgot that i posted this up!
firstly bike weight = 20.2kg...will get it below 20kg after i swap out the ugly stem and some 09 saint cranks
the saint brakes are the best ive owned, ive had codes and juicy 5+7. Everything you've read about them is pretty much true!
the forks are buttery smooth! i had initial setup problems but thats all been sorted. forks run almost 1L of oil bring the fork aprrox 3.6kg. With a bike like the foes, weight is never an issue :D
Discussion Starter · #9 ·
Update 28JUL10:
the original powdercoat started to flake off from day one and the frame was looking a bit shabby so with lots and lots and lots of time on my hands...
imo...much better than white:)
1 - 12 of 12 Posts
