1 - 8 of 8 Posts
A wheelist
nathasm said:
Any used both chainrings and can give a performance difference?
If I understand correctly, neither are ramped, but the CD's at least come pinned. But are they both durable and yield good performance?
I've got a mixture on my bike - CD granny and Boone middle and outer. None come ramped but I read that Boone will pin them if asked. I've had my CD granny for about ten years, the middle for about 4-5, uhhh maybe seven, and the outer for two. None show any wear at all and work perfectly. Ramps and pins aren't an issue for me as I can shift without them.
As far as I'm concerned, they might be expensive but when you figure dollars per year they're the cheapest.
The Cycle Dynamics I bought a couple of years ago has both pins and ramps and shifts very well. It is not quite up there with the best Shimano, but it shows almost no wear after 2 years, I was previously killing XT middle rings every 6 months. It should pay for itself several times over.
The CD is also cheaper than Boone, about $50 I think.
I Have Been Running A-T and Boone
on my rig. I have an Action-Tec heat treated outer ring, Boone middle and A-T granny. The A-t's are both about 2 years old and still look brand new. The Boone is only a year old. Loved both sets. Have a Boone SS HD ring on the SS and have to admit, nothing looks as good as the Boone outers!
I'm running Cycle Dynamics granny and middle on both of my dual suspension bikes. I used to replace the steel grannys' every couple of months due to the teeth being compacted. I'm a little biased as C/D is a local company and I've watched the manufacturing process using the gear cutting equipment rather than machining or stamping.
Are the Boone's made with the gear cutting tool or are they machined/milled/stamped?
Also, i've read that the Boone's require spacers or washers between the middle chainring and the crank to achieve correct spacing... Do the CD's require spacers/washers?
No washers required with Cycle Dynamics, at least not with Raceface cranks.
1 - 8 of 8 Posts
