Baldone said:
What exactly makes the Bonty Jones tire a lesser rear tire, than other choices?
Here is a tire weight approximation for some of the two niner options - just to compare:
InterWolf Comp weighs 420 grams per tire. (Inflates to about 1.5")
Mutano Raptor weighs 540 grams per tire. (Inflates to about 1.75")
Bontrager ACX weighs 570 grams per tire.
Conti Vapor weighs 590 grams per tire. (Inflates to about a 1.8")
Nano Raptor weighs 600 grams per tire.
Moto Raptor weighs 640 grams per tire.
Notos XC weighs 665 grams per tire.
Kenda Klaw weighs 680 grams per tire.
Mythos XC II weighs 690 grams per tire.
Schwalbe Big Apple 2.00" weighs 835 grams per tire.
Schwalbe Big Apple 2.35" weighs 935 grams per tire.
Bonty ACX is the lightest big meat tire currently available at 570 grams and is a fast roller. You save a 1/5th to a 1/4 pound of rotating weight over some of the heavier tires, but as others have pointed out - it's a "softer" tire with durability issues based on what type of surface and terrain one faces. I use it front and rear as a set.
I face a lot of mud due to annual rainfall and wanted a tire that could shed quite well. The Bonty's have been champs for me on surfaces where I had to use Continental Survival Pro's on my 26" ride just to keep moving up the hills. I do not ride on pavement with these tires and oodles of sharp rocks are not part of the XC experience where I live. So, for me, the tire performs very well and durability issues are not a problem. I am approaching one year of offroad use on my front tire and see little tread wear - probably due to the surfaces I encounter on my rides. I did ruin the kevlar bead of my first rear Bonty because I turned it inside out too many times trying to hunt down some hard to see thorns. I broke the dang bead in one spot and learned a lesson that cost me $40 for a replacement. I pretty much removed the benefits of my rear tire being light weight because I now run a Bontrager Slime tube in the rear due to the thorns I encounter. I haven't had a flat using this combination. The front is run with a WTB tube and has been problem free in terms of thorns.
If considering the Bonty as a rear, factor in the type of surfaces you ride on when making a decision as well as what type of a rider you are. On dirt, gravel, roots, singletrack without too many rocks and mud - I have found it to be a high quality tire for my purposes. It reminds me a little bit of the hook up and feel of Panaracer XC Fire Pro's - only the Bonty's are much better in mud than those tires were due to the wider knob spacing.
BB
