Let me first say that I have been running a set of Race Lite Wheels and Jones ACX TR 2.2 on a Fuel EX9 for about three months now with tubes because I wasn't sure if there was any advantage [for me] to go tubeless. I've been using this setup in a lot of sandy & hardpack conditions and they've been a little slow, so I figured I'd give tubeless a try to see if it made any difference before trying a different tire.
Since I can't ever just let my poor bike sit when I'm not riding it, I decided to ditch the tubes and add Super Juice yesterday before a 16 mile trail ride (probably not smart but what the heck). The whole process was very easy from start to finish - it only took about 15 minutes per wheel! I aired them up to 40 psi and hit the trail. My first impressions is that at 40psi tubeless feels a lot firmer than 40psi with a traditional tube? Anyway, after airing them down to around 30psi they felt better. I had no leaks, and at the end of the ride they had only lost about 2-3psi, less than my tubes usually loose. Both tires lost about 4-5 psi overnight, but nothing major.
Here's my question. Other than the obvious weight savings, no more pinch flats which I rarely get anyway, and ability to run lower psi, what are the pros/cons to tubeless? How low can I go in terms of psi (I weigh 205 and am fairly aggressive)? Anything else I should know about running tubeless.
Thanks.
Thanks.
