1 - 3 of 3 Posts
· Registered
I need some help on a ss build. Using a mid 90's privateer frame with vertical dropouts. Do i need a chain tension device or is there a gear ratio that will work instead? I noticed some builds using 36:18 that seem to work. I'm new to this and used the search function already. Thanks,
· you said.. Member
It will help to know the chainstay length, that way you can pick the correct gear combo to span the distance without a tensioner and get the ratio you want. You may need some funky sizes though. My old Fisher works perfectly with 32x18.
I used ssConvert to do the calculations:
http://www.teambigtime.com/software/ssConvert.htm
it seems to work well. YMMV.
Also, check the FAQ above has lots of info. http://mtbr.com/faq/ssfaq.shtml
HTH
· Retro Grouch
Worked for me...
I had a medium 98 Bontrager frame and a 32:18 worked without a tensioner. The rule of four says if the frames are the same 36:18 should work. I also used a half link with a 32:16 with no problem.
1G1G, Brad
1 - 3 of 3 Posts
