I have a Trek Roscoe 7 2020. The rear hub is absolute garbage and Trek took ages to respond to my warranty claim. Finally they did and through my local shop they would send me a replacement wheel. This wheel would be the same as the stock one, so only fixing my issues temporarily. However they sent the wrong wheel; namely the Bontrager Line pro 40 rear wheel. The shop told be it wouldn't fit my frame, though I had heard some hubs, for example DT swiss 350 could be converted from boost 148 to boost 141 using QR end caps. I did some research and found the same kind of end caps compatible with the Bontrager Line Pro 40's hub on Trek's website. The items I found are W527033 and W562022. To be sure and use your knowledge; will these fit on the wheel I was talking about and will buying these two parts convert the hub to Boost 141 QR and thus fit my Roscoe? Thanks in advance
Trek sent me a rear wheel which is probably more expensive than my frame lol.
