The Bombtrack Beyond+ ADV looks like an absolutely incredible bike. It checks nearly every box that I personally have on my list of requirements... except one -- there's no sliding dropout option for an easy singlespeed setup. That fact just boggles my mind with a modern steel frame, but it is what it is.
I'm worried that EBBs and tensioners add complexity, may alter the geometry, or simply can't/won't hold up well in the wilderness on tougher/longer bikepacking trips. Is that a legitimate concern, or am I overthinking the issue?
Question 1: Has anyone seen a decent singlespeed configuration for the Bombtrack Beyond frame? If so, what was it?
Here's my short list of requirements:
1. Must be steel
2. Must work well with 29x3" tires
3. Geometry must work well with 120mm or 130mm suspension fork (525mm and 535mm a2c measurements, respectively)
4. Must have stealth/internal routing for dropper post
5. Must be boost rear end (148x12mm)
6. Must be fairly inexpensive -- I can't afford a custom frame, so it needs to be in the same ballpark as the Bombtrack, or less.
7. Must be easily converted to singlespeed with sliding dropouts.
8. Must have mounts everywhere on the frame for packs, bottles, front and rear racks, etc.
Question 2: If converting the Bombtrack to singlespeed is a bad idea or may cause issues, what other frame options out there match ALL of my criteria above?
Please and thank you!
For reference, here are the beautiful Bombtrack offerings:
2019:
2020:
1. Must be steel
2019:
2020:
