pardon my ignorance, just trying to learn: ETA gives you 30mm when locked out, for example if you locked out on a climb... and the ECC5 does not reserve travel, correct?battlescars said:The "04 marathon S os a coil spring fork and has ETA which when reduces the ride hieght by locking out rebound when switched on, but preserves 30mm of travle at the end.
The "04 Marathon sl is air sprung and has ECC5 which is a 5 position rebound control. It essentially does the same thing, however you don't get the prserved 30 mm of travel.
These forks are awsome, both ETA and ECC are incredible for climbing. I had a Marathon SL, and still consider it my favorite fork to date. Simple to maintain and set up. the major differences between the 2 are weight (coil vs. air) abd that 30 mm of boing when eta is in lock down.
BTW you'll be impressed with the lateral stiffness of either coming from a SID.
I think you could set up either fork to work well for you, but I would go with the air version (SL) since you really won't need the coil. The deal is that coils can be set up a little more linearly (sort of equal to being plusher) than air. However Marzocchi's dual air system makes the air forks very plush (doppi air). I would save the weight and go with all air.formica said:pardon my ignorance, just trying to learn: ETA gives you 30mm when locked out, for example if you locked out on a climb... and the ECC5 does not reserve travel, correct?
next, I couldnt' find weights on these. I'm a little thing, small female (#130) is that going to be too light for thse forks? My riding style is XC "on the verge" ( ie I like technical)
any other differences between air/coil I should be aware of? Or just let the best deal between these two on the web be my guide at this point?
thanks for helping.
The only problem with the 05 SL is that it does not have the on the fly travel adjustment feature, which is essential for a 120 mm fork. I think there should be a 80-100 mm travel version of the SL: it would work much better. For a 120 mm fork, you need ETA and and coil in at least in one leg...robsetsfire said:I think you could set up either fork to work well for you, but I would go with the air version (SL) since you really won't need the coil. The deal is that coils can be set up a little more linearly (sort of equal to being plusher) than air. However Marzocchi's dual air system makes the air forks very plush (doppi air). I would save the weight and go with all air.
I would look at the 04 SL, 05 SL or 05 Race. I have an 05 SL and love it. I came from riding a fox float RLC which was nice, but not great.
ECC5 does not reserve travel, ETA does, but ECC5 has 5 settings where ETA is on or off. The 05 line has TST instead which works more like a selectable lockout than a lockdown.
One note, the 04s are getting hard to come by and you should start to see the 05s drop in price. Places will be willing to make you deals on the 05s, I would try asking and don't recommend paying retail at this point since I'm sure you can do a lot better.
I think a light rider is better off with something like the Manitou Skareb Platinum. Infinite travel adjustment up to 100 mm, 1500 gr, should last for a long time and not so expensive. Stiffer than a SID, for sure. If you don't need travel adjustment, try the Skareb Super. Marzocchis are for big guys, who would need 150-200 psi in a Skareb to work properly...formica said:I need some clarification...
what is the difference between a marathon S '04 and SL?
I'm looking to replace a SID race, and one of these seems like a likely candidate, thanks
formica
If you are coming from the 80mm sid, I would very much consider the 80mm Marathon Race. Right now they are a bit expensive, but it is a great fork and should outperform you sid in many ways.formica said:OK, thanks, just trying to process all the info. I'm also concerned about going to too much travel/weight after the 80mm on the sid, bike is a Kona King Kikapu (01)
I asked earlier about a FAQ, maybe what I need is a dummie's guide to front suspension.
why would I need/want a travel adjustment? what is it about stiffness that's important?
I'll pay you guys back with technical fabric info if you ever need help, that's my area.
formica
Let Formica see the whole range instead of just pointing out one possible fork! Undoubtably Manitou Skarebs work better for lighter riders, though the Marathon Race is a better functioning fork for someone like me, who weights 160 lbs.robsetsfire said:If you are coming from the 80mm sid, I would very much consider the 80mm Marathon Race. Right now they are a bit expensive, but it is a great fork and should outperform you sid in many ways.
True. Unless she chooses the Skareb Platinum, which has infinite travel adjustment from approx 20 mm to 100 mm...robsetsfire said:The extra travel will probably change your bikes handling, particularly the steering characteristics a bit. A 100mm fork probably wouldn't be terrible although it may take you a while to adjust. A 120+mm fork would be too much in my opinion. Remember that your King Kikapu was engineering for an 80mm fork.
The minimum travel I could get from the SL I tried was 108 mm. I never use the TAS feature of my XC since it has ETA. It's set at 120 mm which is perfect for the Specialized FSR 120. But it can be set as low as 97 mm with TAS, if I transfer it to another frame. That's 11 mm difference in adjustment range.robsetsfire said:I don't use the travel ajustment on my SL much. I have it set between 105 and 110 mm and don't play with it.
I don't think you can say that undoubtably Skarebs are better for lighter riders and Marathons are better for heavier riders. Better is pretty subjective. They may be lighter, but I see no reason that a Marathon/Reba/Fox can't be used and liked by a lighter rider.macsi said:Let Formica see the whole range instead of just pointing out one possible fork! Undoubtably Manitou Skarebs work better for lighter riders, though the Marathon Race is a better functioning fork for someone like me, who weights 160 lbs.
... although I'm not sure that I did a great job answering it because most of the discussion revolved around 05 forks that are undoubtably more available at this time, but also more expensive.formica said:I need some clarification...
Yup, 105mm is tall for that frame. I had an '01 Mano with 100mm Z5, and it steered quite slow, I had to really lean over the bars in tight singletrack. Ideally get a fork in the ~80mm range, or will dial down to 80mm.heatstroke said:If you had a 80mm SID on your Kona, even a 105mm Marzocchi SL will be too long and really mess up your climbing, and steering. Marzocchi seem to run about 10-15 mm longer than RS or Fox.
I'd recommend you do not change the Axle - crown length by more than 10-15mm compared to your current fork other wise you may not like the sloppy steering.
I've been riding an 105mm SL (03model). It is now replaced by a 115 mm Reba, which has a similar A-C length. I think the Reba Team is a better shock than the SL. You may want to consider the reba with U turn so that you can dial in the travel/ac length, you could drop it all the way to 85 mm and then increase as you experiment
The Reba is stiffer (feels like it at least ) and is about 150g lighter.
Yeah... cool...macsi said:I really enjoyed the discussion with the head engineer, but I can still see other forks through the Marzo haze...
-b
Re-reading my comment, it might have been a bit too strong. All I wanted to say is that there are other forks than Marzocchi - though I personally like their attitude to providing models that last several seasons instead of just one (RockShox) or maybe two (Manitou) for a normal sized rider (160 lbs).robsetsfire said:Yeah... cool...
Someone wanted information about a particular fork which I tried to provide. I'll keep quiet in the future. Sorry to have offended you.
