1 - 4 of 4 Posts
· Registered
Hello all,
I have recently purchased a used tracer 29 frame. It's a bit of a gamble as i have never ridden a 29er! Anyway, I don't have any information regarding bolt torque settings so if anyone can help it would be appreciated.
Also, is there a procedure for greasing the bearings or is it just a case of pumping it in. Don't know if the idea is to 'flush' old grease out by loosening the outer bearing caps.
Thanks in advance.:thumbsup:
· Registered
Oh, and as for the grease: Don't loosen anything, just pump grease into the zerk fittings until you see fresh grease oozing out at the links. At least that's what I've learned as of late - I need to start doing that on mine, as I've just installed new bearings since the old ones were shot.
1 - 4 of 4 Posts
