I had two sets of Delta Axle Rodz, and they would strip if I looked at them funny. They had very loose tolerances between the threaded alu nut on the end and the steel bolt. THe nut on the end would tap dance in the threads a bit, it was so bad.vizsladog said:I have a set of stans crest ztr and use bolt on skewers to stiffen it up.
I can fell the dif. when i dont give them a good snug. But i dont want to over tighten them.
