1 - 11 of 11 Posts
Keep on Rockin...
Can anyone recommend a good bolt on skewer?
How about these from IRD? Any one with personal experiencewith these?
http://www.interlocracing.com/platinumskewers.html
I've repeatedly broken the cheaper varieties. And the last set I got gave a max torque of 7N. Not much as far as I can tell.
The best option, by far, are Paul Word bolt on front hubs. However, I still have a few front hubs that are standard QR setups. I've noticed that the bolt on set up makes a much stiffer front end, and I'm all about that.
Thanks in advance.
Mike
Sofa King We Todd Did
I was running the Nashbar bolt-on skewers on my Surly 1x1 for a while - they work quite well if you aren't terribly hamfisted - but after one thing led to another, I swapped out the quick-release axles on my 1x1 and Karate Monkey to 10mm solid axles with track nuts.
The Nashbar skewers - while cheap (around $10) and work well enough - can be a bit dodgy. Sometimes you order a set and you'll end up a rear skewer that's not long enough, like it was made for a 130mm road hub, despite what the packaging says.
I have noticed the solid feel in the rear with the solid axle. Maybe a solid axle will work better than a bolt-on skewer?
Keep on Rockin...
Discussion Starter · #4 ·
I like to think it offers a stronger hub-fork interface...
pvd said:
what is the advantage of a 'bolt on skewer' over a standard quick release?
is it just a security thing?
if i can't run a skraxel then i run a through axle. Performance, light weight, and convienence.
Seems like you should be able to torque a bolt on more than a QR. I could be totally wrong on that one. I'm a huge fan of thru axels but don't run a squishy fork on my bikes currently. They all have rigid steel forks. I'm probably splitting hairs though as a rigid steel fork is, well, pretty rigid and flex free anyway. But, I have had steel forks with a lot of give and they did "give" a little in the wrong way during hard turns.
Thanks,
Mike
The problem with the skraxle is that the QR mechanism has way too much friction. You can't get it tight enough unless you want to put a cheater bar in the QR lever.
It is a good idea, just poorly executed. Specialized (or whoever made it) did not use a good bushing material. A friend had a new end cap made out of brass for his and it is much better.
pvd said:
never a problem with mine. shouldn't be any less than a traditional skewer.
1 - 11 of 11 Posts
