does anyone know where i can buy a bolt on axel for my shimano xt rear hub? or can u not get them for ur rear? this is a picture of one that i got from TNC a while ago/
im guessing since there stiffer then Qr they should be stronger also?XSL_WiLL said:They're stiffer.
If you do it yourself, just pretty much remember how you took things out, and put them in with the new axle the same way. Pump it full of grease. And tighten things down, but no so much that it won't spin freely.
Any LBS SHOULD have them.
stronger I bent 3 of those QR's on my Big Hit and then switched to the bolt with no problemssaviorself said:why would you use those over qr? is the an advantage?
i switched out my front qr for the solid axle and it kicks asss. 15 bucks vs. new lowers and hub (dj3 on a p1 so probably 150 bucks to go 20mm).saviorself said:why would you use those over qr? is the an advantage?
the bolt on axles are all the same length, you just cut to fit, or you could leave it long for doing nose pickers and rail grinders.rpet said:Anyone know the proper size/length of solid axle for the front Deore Disc hub?
