Cool,thanks for the info. I'll try to get all the slack out, make sure the cables are lubricated, get the right angles on the parts, the right spring tension, etc..... The brake is a standard u brake with weak lookin pads.ihatemybike said:Think of it as two different systems, Lower and Upper.
Install the lowers first, making sure the cables are pulled all the way down.
Install the uppers, adjust till their is no play.
If you are installing with v-brakes you need to make sure that you have enough space between the Gyro plates to get full movement. Also, know that Vs push the cable movement limits of the stock cables, but a Primo Pervert can increase it.
