1 - 12 of 12 Posts
I'm sick of my cranks coming loose and am thinking of making the switch to some profiles or something. I think I have everything figured out except the spindle length. The bike is a p2 with a 73mm euro bb. It runs a 56mm chain line because of the offset rear triangle. Will a 6" spindle be enough to space the chain out that far and still have good engagement with the cranks?
andy
Discussion Starter · #4 ·
hmm.. The way I figure 6" is about 152mm. With the spindle centered that gives me 76mm on either side. Chain line is measured from the center of the bb shell so 76mm -56mm chain line should give me around 20mm past the sprocket to engage the cranks, probably a little less. If I'm thinking about it right that is. Is that enough engagement? They offer a 6 7/8" spindle which would give me around 30mm. The big question is, how far onto the spindle do the cranks need to go. I can't seem to dig that number up anywhere.
thanks,
andy
Bikes Rule
6" should be fine.
But you need to consider the length of cranks and what size chainwheel you have. That will have a huge affect on the spindle placement and fitting.
Discussion Starter · #7 ·
The cranks will be 170 or 175. I might give 170 a try to get a little more clearance, but I don't think it'll make much difference. The chain wheel is 34t but it's a geared bike and is going to stay that way. I want to keep the chain line where it is now, 56mm or so, to keep the chain lined up with the 18t cog in the back. It'll stay on when I try to ride fakie in that gear with that chain line.
Don't go shorter then 6", if you order them from a BMX site and they don't tell you the lenght of the spindle then its probly less, like 5 and something.
ANd If you get profiles you can run a splined sproket which is good for spacing things out.
Discussion Starter · #10 ·
Well, profile got back to me and suggested I go with 6 7/8", though it looked like a canned response. Does anybody know about how thick the cranks are at the base? I should be able to figure it out with that number.
andy
Bikes Rule
My Profile race cranks are about 33mm thick at the base. Subtract about 4-5mm for the bolt spacer (non-splined section) and I figure ~ 27-28mm as usable amount of spindle interface on each side..
Just as a comparison I have a 6" spindle with a euro BB. I use one cone spacer, 2 thick spacers and 1 small spacer on the non-drive side. Tree splined and one spacer on the drive side (no cone spacer). The Tree is so thick that I can't use the cone on the drive side.
My chainring is a 24t and it is about 2mm from the chain stay. Crank arms are as close as they can get without hitting the chainstay at maximum flex.
Pic for reference:
Discussion Starter · #12 ·
Thanks demo-9, thats the info I needed. I'm not going for chain ring as close to the stays as possible, other wise I could probably get away with a 6" spindle. (the 34t ring fit with room to spare using the 52mm howitzer that came with the bike). It's gotta be that far out to get a decent chain line. I was ss for a week, didn't like it, so the gears are staying. That also means that I've got to use an 8 speed chain wheel, so no sexy splined tree wheel. I'm going to use the spider that comes with the profile mtbs and keep my 34t ring for now. I was worried that the 6 7/8" would end up looking like frankenstein with the bolts sticking out past the cranks but it seems that won't be the case.
andy
1 - 12 of 12 Posts
