Fat907- what grease did you use on the Air Shaft? I have some Slick Honey, but the manual says only the RS/ SRAM Butter, or some military grease. Seems like for 20 less than stock on the damper side, you could just pull the old damper and insert the new one without changing fluids... For the air shaft, seems like I just need to remove the rebound adjuster knob and lower bolt on non-drive-side, drain oil, remove the lowers, remove the retaining ring, pull the air shaft out, grease up the new one and install the bumper and floating seals from the old one, and re-install, then add fluids. That's it?
