1 - 2 of 2 Posts
Hello,
I'm bulding the LT2, the problem is that the chain is touching the frame near the
lower link while the gear is in full cross (small/small ring).
It's occurs on the stand without load.
I'm using Token BB with one 2.5mm on drive side and non on the other side
and FSA V-Drive MegaExo crank (taken from my old Giant Reign - 68mm shell).
(http://www.tokenproducts.com/files/technical_manual/f-4aceaf812bc6c.pdf)
(It's not a tension of the chain problem - rear derailleur rings don't touching each other).
Any ideas ?
Have a Marry Xmas :)
My Blur XC does the same thing. Don't really consider it a problem, since I would never use that gear combo. However, you could try a bigger granny gear, or shorten the chain up a bit if you have room. Just don't forget that the chain needs to be longer when the suspension is compressed :)
1 - 2 of 2 Posts
