1 - 20 of 1158 Posts
Won't actually be 'set up' for a couple of days; but, looks really sweet out of the box! 5.68 lbs. More to come. Thanks Zach at Competitive Cyclist.
Cheers.
nice!!!
How are you going to build it up?
Porch
Discussion Starter · #7 ·
Here's the 'build':
Frame: Santa Cruz Blur LT Carbon, medium
Rear Shock: Fox Float RP23
Fork: Fox 36 Talas FIT RC2, 1.5 taper
Saddle: WTB Devo Carbon
Seatpost: Crank Brothers Joplin R, 30.9
Seatpost Clamp: Santa Cruz
Handlebar: Easton MonkeyLite XC, High Rise, 685mm
Stem: Syntace F-119 MTB, 90mm
Grips: Ergon GE1
Headset: CustomTapered headset
Shift Levers: SRAM X.0, trigger
Front Derailleur: Shimano XT M771 Direct Mount
Rear Derailleur: SRAM X.0, long cage
Derailleur Cables: Gore Ride-On Sealed
Brakes: Magura Marta SL Magnesium
Brake Rotors: Magura SL Drilled, 180mm F & R
Crankset: Shimano XTR Hollowtech II Crankset FC-M970, 175mm
Chain: SRAM PC-991
Pedals: Crank Brothers Mallet 3, Aluminum + Ti
Cassette: Shimano XTR Cassette CS-M970, 11-34t
Wheels: Industry Nine Enduro Flow (Stan’s Flow rims)
Tires: Continental Mountain King Protection 2.4 in., converted to tubeless (Stan’s)
Rear Skewer: DT Swiss RWS Thru Bolt, 10x135
Cheers.
Wow, another and another amazing bike/build from you. Does this officially declare the end of the recession? I would love to know what you do to afford all these bikes.
Discussion Starter · #9 ·
My wife would like to know also. I'm trying to instill consumer confidence and jumpstart the recovery.
Cheers.
So where are you heading with this build spec, there's not a great deal of difference between your LT & XC builds other than fork/ wheels, maybe spec the XC closer to it's intentions.
My XCc (24.5lb) feels like an ultra lightweight LT2a (28.2lb) to me, so I'm curious as to what you think the LT2c will be of benefit to you over a more durable alloy frame.
BTW if I post a LT2c here as my own send me abusive PM's as I don't believe that a carbon trailbike is the right decision for me. I understand that the carbon is strong in SC impact tests etc. but there's the everday durabilty issues that concerns me, the rear dropouts with no plated protection from skewers let alone a bolt up rear hub eek.
I'll suffer these on a job specific bike like the XC, but a trail rig....nah.
wow that looks sweet, and it's in my colour too...After demo'ing an alu LT2 at the weekend, I'm planning on placing an order for one of these carbon beauties shortly. Can't wait to see yours built up!
Man, that's what I call beautiful. I thought the Mojo was kinda nice for a carbon bike, but this is beyond imagination. I'm waiting my modest and regular BLT to come, and from my experience with it, I'll probably order a BLTc next year. If a carbon Nomad doesn't show up before! ;)
Hey, is that a press-in BB like those on Pivot bikes?
Congratulations, that will be a really smooth ride! :thumbsup:
Discussion Starter · #14 ·
Gripo: All good questions and comments. I'm not quite sure where it's headed either. I've got three bikes and I'm trying to differentiate them (like fly rods). The XCc should probably be pushed more towards XC. I'll see how it sorts out.
Black Ronin: The BB was wrapped in masking tape. I'll have to check tomorrow. It was represented as a custom proprietary tapered headset. I don't even know who makes it.
Almost together, except the front wheel needed a 20mm sleeve from I9. It will be here on Thurs. Raining now, but supposed to be a good Memorial Day weekend here with temperatures in the low 70's. I'll post some more pictures on Friday.
Cheers.
m_driscoll said:
That is pretty porky. It was only supposed to be 5.6 lbs! Here's a photo courtesy of Competitive Cyclist.
Ahh the .08lb is the seat post clamp :D and the dust on the frame :D
Fantastic looking frame, I'm hoping to have one by the end of the year, keep us posted on your build up. :thumbsup:
just wait till you ride it..
your going to be sooooo stoked! I had a chance to test drive one yesterday.. incredible IMO.
Steve
Ok so my story is I have ridden a hard tail wicked since 1990 or 91. a year & 1/2 ago I bought an older gen1 bruja. (just to give a where I'm at sort of reference). I love the squishy of the bruja- vanilla f & r. So I have been trying out lots of different tires, forks, wheels etc. NOT very tech trails but over and over on the same trail day after day I get a pretty good feel for the changes.
Then my buddy at my LBS is buds w the owner of SC bikes. A few weeks ago he had the XC version.. I did not get a chance to ride that, however when the offer to spin this came I jumped on it.My story is this- just returned from mendo 4 days of riding long weekend, went and grabbed the bike for my morning ride on my way to work. I checked out a few angles and heights to compare to my current bruja. BB 1 inch lower on the LT, Bars 1" lower as well, Seat to bars 1" longer, a plus as my bruja is m and the LT is L . Bars are 27 bruja 26". Seat tube angle looked identical, head tube maybe 1/2 degree more slack- almost identical. wheelbase 1" longer. I weight 170 and 5' 11" tall.
This one had the revalation forks and RP 2.3 shock. Apparently the owner is 185lbs so I did not touch the air pressure. I did reset the orings for reference. Initial sag looked pretty much inline for starters.
I rode Fremont older in Cupertino. I start in the prospect lot. Initial impression was climbing felt good. now I am really tired from riding for a 10 day s straight.. but it climbed well middle chain ring all the way to Maisies peak. I dropped into granny for that. Now I did not lock out anything as far as shocks go.. Then the fun begins.. So I blast down from Maisies and do my normal left and duck oder the tree branches- it feels great. then some fire road, zig zag around the rain ruts, pop a little air off the bump, then to the chopped up from the horses section.. Well I do feel the bumps but it is more like good feedback not beat you up stuff.. Then a bit more fire road and blast a right to the toyon trail single track, now this is getting good.. It is super responsive, back it here, jump off the hump, zig over to the skinny section, up, then down, the roller coaster, then small climb out, back down the next toyon section- fantastic!, a hop here, zig there, a few banks off the side, then back to fire road, through the meadow, short climb then seven springs single track downhill, then climb out. They had done some recent trail work here and for some reason installed about 15 speed bumps / jumps. this bike is tracking wonderfull, goes where you put it, pop off the bumps, then climbing it just goes great.. NO pedal bob like my bruja/vanilla. it has a great 'feedback feel' like pedaling a HT yet softens up the bumps like they are not there. The tire were more xc than what I tend to ride, but the did not slip even on the powder sections like the susp. took up what it needed and made the tires stick.
In the end the rear had used most of the travel so the air might have been slightly too low, front used 3-3 1/2" travel. (even low rear shock pressure had less pogo when pedaling than my bruja)
To sum it up it was a very expensive test ride for me and I have a bruja for sale..
Also I heard they were not quite out for a few weeks or so- or at least not the large ones..
Just my take on it. NO technical stuff involved. I just had the best ride ever IMO..
Steve
Disclaimer- interpret it in your own way. Hope my description compares to yours when you ride it.
