I read thru the sticky, but didn't find what I'm looking for...
After 2 years of being a die-hard SS'er, I've dusted off my old Blur. I have to admit...I LIKE it:thumbsup: Anyway, I've got it set up with a Pushed RP-3 in the back and a Talus 130 up front. I'm ~195lbs with pack and gear, and like agro-trail style riding.
I've got the fork pretty well set-up with 65psi and the Rebound and Compression knobs pretty close to center. I usually get 115-120mm of travel, and figure that's about the best I'm going to do. 130 would be to the crown, so I don't believe it'll really do that.
My real question is on getting the most out of the rear shock. The SC guide (posted in the sticky) says I should run my weight, 195psi. Been years since I've ridden it that hard, but I don't remember getting much travel. Lately, I've been trying to experiment a bit. At 176psi, I had about 14mm of sag and got about 34mm of travel (as measured on the o-ring). At 172psi, I've got about 16mm of sag and get 38mm of travel. I think the stroke is supposed to be 2", so I'm only getting about 75% of the rated travel. My question is, do any of you get full travel? And if so, how much sag are you running?
