1 - 4 of 4 Posts
x-post from Santa Cruz:
Sorry if this is a repost..I searched the archives and could not find an answer to my questions-
I just got a Med Blur, with 5th airshock. The first 2 rides were great, then on the 3rd ride it started sounding like air was leaking out- whenever I would hit a rough bump (rock or log), I would hear the sound of air deflating from the rear. Any idea what the problem may be?
Also, the Santa Cruz site says for the IFP- set it at 50-70psi, but the Progressive site says to not set the IFP outside the 75-125psi? What should it be?? I weigh about 135lb.
Thanks..
Are you actually losing air? The hissing sound you are hearing may be just the damping. Shocks aren't all silent, and it's not a problem. If you are losing air, you'd know pretty quick. Your sag will get lower and lower untill you are riding bottomed out, but I doubt that's happenning. Now thinking about it, if it leaked fast enough for you to hear a hiss, it'd run out of air in seconds. You most probably are just hearing the damping.
50psi if fine for the blur. Go with SC's reccommendations.
Discussion Starter · #3 ·
Good point. Hey, thanks for the help. The FS stuff is all new to me.
SC knows a lot more about what works with their frames than the shock maker that doesn't have the time to test it on a thousand bikes. Trust SC's recommendations and tweak from there. The 5th is a noisy shock, if you're not getting a thud noise the don't worry about it, it's just the damping.
G MAN
1 - 4 of 4 Posts
