define bluing there are several different types
define bluing there are several different typesHi All
I'm thinking of bluing a steel fillet brazed frame, before clear coating. I know this may need to be sandblasted and re-done every couple of years, but I'd be interested in best bluing techniques for bicycle frames?
Yep I think cold bluing followed by a clear coat, leaving the fillets unfinished. It’s goi g to look awesome.you definitely don't have to immerse the part to cold blue it, you can just wipe the bluing solution on the part.
Cold bluing alone is probably less than ideal if applied alone because it gives minimal corrosion resistance. If you clear coat it as you indicated it would probably give a very beautiful finish.
ok im not going to go into anything because basically its a waste but heres one from someone who posts on flikrHi. I know there are different types and that's part of the reason for asking for advice on which would be best for a bicycle frame. I'm awarefollo
Hot bluing, Rust bluing, Fume bluing, Cold bluing, Niter bluing, Colour case hardening and Browning. I'm thinking that Browning and Rust bluing are not suitable, but maybe cold bluing is?
Thanks for sharing. Did you then clearcoat the frame and if so, 1-2 years later how is it looking?I've done it before, works fine. View attachment 1958485
Rattle can clear, cheap spec.Thanks for sharing. Did you then clearcoat the frame and if so, 1-2 years later how is it looking?
Thanks. Yes I’ll be doing a powder clear straight after the bluing treatment. My main concern was whether the bluing promotes more corrosion to start underneath the clear, but I’m guessing if it’s properly sealed it shouldn’t be an issue. I’d love to see some pics of you’re prepared to share? Bluing against fillet looks awesome in my opinion.Rattle can clear, cheap spec.
Looks like **** after a good year of use in high wear areas but all that is due to the rubbish clear. The blue-oxide is still there and looks fairly stable, but some red-oxides are starting to fight for space.
Note the finish is not uniform, as it is applied with a rag. Has a sort of woodgrain-ish like appearance with dark blues and greens. Contrasts nicely against the bronze fillets.
Using two-pack clear will result in a more hardy finish, powder even more so. Problem with powder is that you have to get it coated quick smart after the treatment.
I think you may still get the issue of 'rust veins' even with a clear powder, but that is just a guess.Thanks. Yes I’ll be doing a powder clear straight after the bluing treatment. My main concern was whether the bluing promotes more corrosion to start underneath the clear, but I’m guessing if it’s properly sealed it shouldn’t be an issue. I’d love to see some pics of you’re prepared to share? Bluing against fillet looks awesome in my opinion.
Just thought I’d share a test bit that I’ve done for the paint shop to do a test clear coat.I don't know a lot about bluing but my understanding of it from firearms is the quality of the bluing has much to do with the metal prep. To get the deep glossy finish they bring the metal to a polish before hot bluing it. Less prep, the more it looks like blue colored metal.
exactly thisI don't know a lot about bluing but my understanding of it from firearms is the quality of the bluing has much to do with the metal prep. To get the deep glossy finish they bring the metal to a polish before hot bluing it. Less prep, the more it looks like blue colored metal.
