My rear brake (Hayes Nine Carbon) was very spongy, so I decided to bleed it. I've never messed with my brakes before, but have bled hydraulic brakes on cars and motorcycles and decided I could figure it out.
I turned the brake lever housing straight up and stared at it for a while to figure out how to put more fluid in. I finally decided I had to remove the plate on the housing. Surprise! The screw heads are Torx.
Well, I have a set of Torx screwdrivers, so that didn't really slow me down. I unscrewed both sides and removed the plate. I proceeded to bleed and get the air out while replenishing the reservoir. After a short while, I ended up with great action and was very satisfied. So I put the rubber thing back in and the plate back on.
Then I found the little plug that goes in the refill hole. I didn't know what that was when I got started. After I found it, I checked hayesbrakes.com and looked at the manual. It says "Do no remove the Torx screws or the plate covering the reservoir." Well, isn't that nice, except it is too late!
I can't seem to get the little plug to stay in the hole. I don't know of removing the plate affected it in some way, but the little plug just keeps falling out. This, of course, will result in air getting into the system.
Any thoughts on how to get the little plug to stay in the hole?
