Does your roller roll when you pedal? I just got a new one but it doesnt spin very well after I tighten it. I just lubed it up too.
I just removed the washer between the guide and the roller and now it spins and it keeps the chain from touching the metal piece holding the roller in place.bad andy said:you need to make sure the washer is BETWEEN the roller and the guide. The roller won't roll if it's tightened against the guide.
Thanksbad andy said:ok cool - you must have had an incorrectly sized washer or something.
...just a tip - if you have the plastic wheel, you're going to get annoyed at the clacking sound it makes. You can replace it with this MRP unit. This unit is made of rubber. I did mine and the action back there is virtually silent now.
http://www.jensonusa.com/store/product/CG707Z01-Mrp+Grooved+Roller+Kit.aspx
Does the MRP roller play nicely with Prolink lube, or would installing it require switching chaine lubes?bad andy said:ok cool - you must have had an incorrectly sized washer or something.
