1 - 9 of 9 Posts
I'm going to purchase a Blackspire Stinger Chain Guide for my 2005 six pack but I'm not sure if I want the ISCG Mount or the bottom bracket mount. What are the pros and cons of each?
Lay off the Levers
I have one of each.
-BB mount can be a little easier to install.(depending on things below)
-ISCG mount sometimes has bolt interference btwn the chainguide bolts and the granny ring bolts, if you run the cranks very close to the BB (no spacers)
-ISCG can be quickly mounted and removed by w/o removing the BB cups. Nice. It does not affect your chainline either.
Dirtbag, not sure I understand how you can adjust the ISCG more easily with the cranks installed. How do you reach the mounting bolts with the cranks on? If you leave them loose enough to move the chainguide you still have to pull the cranks to tighten the bolts no? With a BB mount you can leave the cup just loose enough to adjust and tighten afterwards. Still have to remove the cranks to cinch things down though.
The one advantage of the ISCG mount is you can run your drive side cup without any spacers if that gives you the best chainline. (and the bolts don't hit the granny)
Also sinc the Stinger ISCG is slotted it can move from a rock-strike just like a BB mounted one can.
All in all it's sorta 50-50 in my experience.
Team Sanchez
Noosa, what crankset and BB are you running? If you are running an older ISIS or Octalink setup, you will want to go with the BB version of the Stinger. If you have one with outboard bearings, then go for the ISCG version. The Isis and Octalink chainring bolts will rub on the mounting place if you try to use the ISCG version. With the outboard bearing type, there is plenty of clearance, and it's easier to install and adjust.
mr. wonderful
I've got a Stinger on the HL, with Gravity Lite cranks and outboard bearings (doesn't everybody run outboard bearings these days?), and I am able to reach the bolt heads on the ISCG with a hex key through and between the chaos of the spyder and the rings. I didn't really understand the benifit of ISCG until I discovered that little gem. . . smart, now I get it :idea:
Just Grin and HUCK it...
Yup... me too. Only I sport a stinger on a RFX with FSA cranks (don't remember the model) and std BB. Same way to adjust it - through the chainrings. Simple is as simple does...
Discussion Starter · #9 ·
Yeah El C, outboard bearings with XT cranks. Pulled the trigger on the ISCG version. Now the real tough question is what color powder coat for the six pack? Thinking Kawasaki green, or SE Racing baby blue (throw back to my BMX days) or even that army green that ventana uses. Decisions, decisions...
1 - 9 of 9 Posts
