I'm posting a review of my Black Sheep 29er equipped with a Rohloff based upon somewhat over 500 miles of riding under a variety of conditions. Some of it is a rehash of previous reports and it certainly is long. As I planned the bike and got up the courage to go custom, I found reviews on this site to be very helpful so I'm trying to pay back to the system. Furthermore, I've broken the review into two parts, a review of the frame/fork and a review of the Rohloff.
Part 1: A Black Sheep Ti 29er Frame and Fork
I have been cycling for 25 years, both on and off road, and finally decided it was time to go for a custom bike; I ride enough and I deserved something that was not just “off the shelf”. Luckily, I had a friend that had more-or-less interviewed builders the year before so I had a short list. James at Black Sheep had been my friends choice and after James had made me a custom steel fork and fixed a cracked Moots YBB frame that Moots had not been able to and others had either refused to or wanted hundreds of dollars for just trying to, I too ended up using James. He was thorough in his measurements of me and my bikes, interested in my riding style and intent, respectful of my knowledge and ideas, and clearly articulated his opinions regarding the right frame for me. I imagine there are many other builders out there who fit that description. And it all happened at a price point well below the big name Ti builders. What more could I ask?
I had some clear ideas of what I wanted when I decided to get a new bike: a non-suspended (fully firm), quick handling, 29er. To get that I had to go custom. My premise is that all mountain bikes have too large a trail measurement, and that appropriate trail is best generated by a fork with a relatively large rake. Consequently, I spec’d a bike with a 72 degree head angle and 50 mm of rake. I was also committed to avoiding suspension so I didn’t bother to have the fork made accounting for front suspension. Additionally, I demand a low Q-factor crank and the bike needed to be built with clearance for the crank. Perhaps this squeezed in the chainstays enough to limit a large rear tire, but there’s plenty of clearance for a Nanoraptor and that serves me just fine. James at Black Sheep has a method for cutting away some of the tubing where the chainstays meet the bottom bracket shell to increase tire clearance, so it is an option for me in the future.
Specs
Frame: Ti Black Sheep with EBB
Fork: Ti Black Sheep, 425 mm from dropout to headset race
Important numbers: HTA 72 deg, STA 74 deg, fork rake 50 mm, trail with 50 mm tires is 65 mm, effective TT length 24.25”, chain stays 17.45”, ~12” bb height, 61 mm of bb drop
Rear Wheel: Rohloff Speedhub 500/14 OEM2, built 2X on IRD Cadence Rim (32 spokes)
Front Wheel: King SS in black, built 3X on IRD Cadence Rim (32 spokes)
BB: Bushnell EBB, Phil Wood Ti bb
Crank: Ritchey Logic Compact, 154 mm Q-factor, 34 tooth ring
Pedals: Bebop Stainless Steel
Seatpost: Easton EA70
Seat: Serfas Moots Cordura
Brakes and Levers: Avid Single Digit 7
Stem: Moots Ti 120 mm 0 deg rise
Bars: Moots Ti riser
Tires: Nanoraptor rear, Ignitor (or Mythos) front, Stan’s tubeless (with rim strips)
Weight: 24 lbs., 0 oz (on a WalMart fish scale)
The seat tube angle is steeper than I have ridden in the past, but it seems to place me in a better position on the bike from front to back than I have experienced before. I feel as if I am far enough forward to have quick steering response but I also never fear the dreaded endo, something that was a weekly occurrence on my old Moots YBB. I suspect the big wheels have something to do with that, but James’ design also deserves credit. The Ti fork is extremely compliant but also precise when it comes to steering. I could not keep up with my fully-suspended riding buddy as he bombed down the Porcupine Rim trail at Moab, but then I never have and this bike was built for the majority of my riding, not the once every other year weekend fling. I also love Ti for its durability and ability to take a beating and keep on looking good. I fell over against a boulder at some point last weekend and ground my frame and fork against a rock as I struggled to extricate myself. A steel bike’s paint job would have been trashed, but the few scratches in the Ti were easily buffed out.
The IRD Cadence road rims are light and sturdy, standing up well to the rigors of Moab rocks and Fruita single track. I do not hesitate to recommend them for anyone’s build and they sure set up nicely with Stan’s tubeless. I have yet to feel I need more brake, so the V-brakes work well for me and I like their simplicity and relatively light weight. Finally, I am a fan of Ti bars and stems as the last thing I want is failure of the controls. Furthermore, stiff stems and bars are not needed to improve steering precision when you are not dealing with a suspension fork.
Like many other custom builders, James apparently uses a different calendar than many of us. None-the-less, the frame and miscellaneous parts showed up pretty close to when promised and at a price that should shame Moots, Seven, and IF. I own a Moots and a Seven and can state with confidence that James’ craftsmanship is as good. For the life of me, I cannot fathom why anyone would pay the prices demanded by Moots, Seven, or IF when there are any number of highly-skilled custom builders capable of dealing with you one-on-one at almost half the price.
Specs
