I have the RTWD on my Minute 1 as well. It changes the fork travel which changes the ride height. Mine adjusts from 100mm of travel up to 130mm. Yours may be slightly different as far as the amount of travel goes but the effect is the same.josh said:I've been out of the sport for awhile. I bought a jeykll with a black elite "rapid travel wind down". Could anyone explain to me what that exactly does? Thanks guys
To use RTWD you hafta compress the fork alll the way down and than turn the lever(usually on the top left). this will either raise the fork to its max sewtting, or lower it to its lowest setting. only 2 settings...josh said:I've been out of the sport for awhile. I bought a jeykll with a black elite "rapid travel wind down". Could anyone explain to me what that exactly does? Thanks guys
No, what you are describing is the Rapid Travel Adjust (RTA). The RTWD is infinitely adjustable within the travel range with a few turns of the dial.nufenstein said:To use RTWD you hafta compress the fork alll the way down and than turn the lever(usually on the top left). this will either raise the fork to its max sewtting, or lower it to its lowest setting. only 2 settings...
Additionally, RTWD maintains a constant spring rate throughout the range of travel adjustment. RTA loads up the coil in the short travel position.Homebrew said:No, what you are describing is the Rapid Travel Adjust (RTA). The RTWD is infinitely adjustable within the travel range with a few turns of the dial.
Two positions sounds like RTA, unless Manitou is messing with their catchy little names.nufenstein said:I have a 2004 black elite with rtwd2 and i thought it only had two settings, 80mm, and 100mm. Is this simply not true, or is rtwd2 a ghetto version of rtwd.
