Water, sponges, brushes, and elbow grease. :thumbsup:braxis said:I am looking for a way to wash my bikes being both bike and environment safe any ideas
whenever it needs itburger49 said:Even if you dont wash the bike often, how often should you clean and lube the chain?
electric pressure washer.braxis said:I am looking for a way to wash my bikes being both bike and environment safe any ideas
Ok, so the areas that need to be scrubbed are the derailleurs, chain, crank, and cogs? and then only the chain needs to be relubed correct?ADDam said:Dont use any kind of pressure. I will typically use diluted simple green, spray the bike down, scrub the needed areas and then use the hose and MIST everything off, then wipe down with a towel.
Remember that cleaners like Simple green are also degreasers, so dont forget to regrease (oil) the essential parts.
Simple green is safe for the environment.
Chain and any pivot points (bearings, bushings, etc) on the bike frame and both derailers.six foot sloth said:Ok, so the areas that need to be scrubbed are the derailleurs, chain, crank, and cogs? and then only the chain needs to be relubed correct?
Not after washing but once a year, pull the axles and inspect the bearings and relube or replace them. Also, pull the cassette off and inspect it, and the freehub, for wear/excess play. Google how to do the above. Easy to do and just a few inexpensive tools needed, i.e. chain whip, cone wrench and cassette removal socket.ACSN said:Do you need to lube the wheel bearings/axle (if that is the correct term for it) after washing? I am trying to learn basic maintenance and have been reading articles on the Internet and youtube videos. I always see lots of videos on cleaning and lubing chain and derailleurs but other parts not so much. If someone can post some links, I'll continue reading. Thanks.
I have done this as well. I used a hot bucket for the first rinse and a cold bucket after I had done the scrubbing. You have to be careful, the hot water will take the grease away from the chain, etc.teders said:So lately ive had some problems washing mud off my bike after a nasty trail ride, mainly because of the cold. As you all know turning on the hose for any reason during the winter is a bad idea because the pipes will freeze over night or what ever.
So what did i do? I filled up a bucket with warm water from the faucet and it literally only took me 5 minutes with a long bristled brush to completely remove the caked on frozen mud. I swear, warm water cut through the mud like a hot knife through butter. And afterwards my bike looked sweet all steaming and dripping wet in the cold night air.
Try it out.:thumbsup:
