Weirdest one I tracked down was a plastic shift cable ferrule clicking against the dry metal inside the housing stop on the top tube when the frame flexed - was pretty hard to pinpoint as it wasn't regular and I could only hear it on the road. Shoot some chain lube in there a few times a year now.
You said it wasn't crank related so ignore this, but if it helps anybody else the joint between the spider & right crank arm on a set of shimano hollowtech cranks caused a clicking that led me around the frame for a while before I swapped out the crankset.
Good luck.
Good luck.
