Amen Brother...
El Caballo said:
There is not a single mass-produced bicycle company that pays the slightest attention to weight distribution.
If they did, chainstay lengths would increase for larger frame sizes just as top tubes do. As it is, taller riders have their weight farther back than shorter riders, because no matter how long the top tube gets, the chainstays stay the same length.
This is because bicycle geometry is driven by fashion and uneducated pronouncements from bicycle magazine writers, not by physics.
I've tried to tell people that the larger frame sizes should have slightly longer chainstay lengths, but they don't understand the concept of Center of Gravity.
The best demonstation I've been able to come up with, is to show the bike in a 30 deg. nose up attitude and show them how the taller seat height ( used by taller riders ), in relation to the bottom bracket, plus the larger rider's butt overhanging the back of the seat, puts the rider's weight close to or even behind the rear axle, which makes the bike want to "loop out" on climbs a lot easier.
You can watch smaller men and women on the same kind of frame, on the same percent grade and notice that their bodies are well forward of the rear axle path, becuase the seat is lower for shorter persons. ( Remember to visualise the bike at a 30deg. angle.) This puts a lot more weight on the front wheel. Its one of the reasons smaller riders can climb so much more efficiantly. Its not just that they are lighter, its also because their Center of Gravity is in a much better spot. I think it might also be the reason, that all of the riders I've meet, that like 29ers, are taller. Those bikes usually have longer chainstays to accomodate the larger wheel size.
In addition to El Caballo's reasons, I believe that the chainstay length is the same for all frame sizes, to make production cheaper and simpler. That way, they don't have to waste time, making sure that unappropriate seat and chainstays parts aren't attatched to the wrong main frame.
Later, Eric
