1 - 20 of 41 Posts
Has anyone ever tried adding weight to your bike or hydration during off months. Say to the tune of three to five pounds. It's rumored that Tinker Juarez uses extra weight during off season base rides. Any opinions ? Thanks
In my racing days I'd fill 2 water bottles with sand and then water. I'd also set my rear der limit to keep me out of the biggest cog.
Then I'd go climb the steepest 2 mi climb we have around here 6-8 times.
I'm sure it helped some.....
I can't see that small of a weight really making a difference.
I say just ride and do your thing. If you really want to get stronger legs over the winter, hit the weight room.
Just MO.
is there really a difference between adding weight to your bike to put more stress on your system (so that it adapts and gets stronger)....or just going faster overall to put more stress on your system?
i don't think so. in the end its all just transferring power to the pedals. going faster requires more watts at the same weight. adding weight requires more watts to maintain the same speed. its the same thing. maybe mentally it would make you feel faster once you take the weight off...but imho that novelty would wear off after a couple rides.
particularly when the difference is ~5lbs, which isn't much. that's like 2.5 liters of water, or less than the difference of starting a ~50 mile ride with a full camelback, and ending the ride with an empty one.
I'm going to throw in what I think. I appreciate any helpful criticism. Point me out if I am wrong in any way.
Lets use a typical 3 mile climb to your favorite single track. I will be using myself as an example. Rider weight is 135 pounds. During the entire climb, the rider averages 200 watts and a speed of 11 miles per hour. Now if weight is added to the rider, but the amount of wattage out put is the same, (200 watts), the speed at which rider is moving at will be less than 11 miles per hour. This where gearing comes into play. Rider is putting out 200 watts, but using different gearing than before. Keep in mind that effort is still the same.
Now if the rider wanted to maintain the speed of 11 miles per hour, then the rider would have to increase the amount of watts being produced. Simply producing the same amount of watts before (200watts) would have little benefit as the rider's effort would be the same with or without the added weight. So if the rider tried to match the original speed (11mph), the amount of watts produced would be higher than 200 watts as more energy is required to move the rider and the additional weight at that speed.
So despite adding the weight, while riding you may feel like you are exerting the same amount of effort as you were exerting before the additional weight, but because of gearing, you simply go into an easier gear. Effort will be the same, but rate of speed will decrease. So the idea I would guess would be to match your original speed, and not go based off of effort.
Now if you were hauling 50-100 pounds in a Bob trailer up hill, you definitely would get a work out as the sheer amount watts you have to produce to is just necessary to keep you rolling forward.
This why single speeds or 1x9 setups are awesome during the winter because you are using a different gear. It why typical single speed rides have faster ride times, simply cause you have to stay on top of gear or else you have to walk up hill. Law of the single speed. Think about it, what would be harder, riding with extra weight or 1x9 (35t chain ring up front)?
No. Just No.
Or to accomplish the same thing someone could just ride their normal setup without adding extra weight, but cover it in less elapsed time. Either way it's It's not rocket science - just 2 different ways of creating higher effort input on rides when you want to work harder. However, only one retains the benefit of familiarity and specificity of the race day configuration, plus promotes becoming more accustomed to higher speeds.
The White Jeff W
How about bigger front chainrings?
I run 24/34 on my 26" bike & 24/36 on my 650B (both 2x9, obviously).
The 24/36 combined with the 27.5 wheel is much harder to spin than the 26" bike. I'm leaving it for the winter then will probably change the 36 to 34 in the spring unless I get a lot stronger and can spin the taller gear, which would rock. :thumbsup:
LA CHÈVRE
I just ride another bike in the winter, it's heavier, only has a 42T chainring, slower rolling tires, and at -20C, the brake seals don't bring the pads back in as much so they drag a lot! :p
It's also crapier, so I don't ruin my good bikes in the snow and calcium. That's the primary reason I use it.
mutaullyassuredsuffering
This comes up every year, and I have only encountered 1 situtation where I thought it made sense. Some guy posted last year, that he lived in a rolling hillly area and all the hills were pretty short. He wanted to get in 3 min intervals without breaking them up (by descending to the next hill) so he would add weight and ride the hill at similar intensity...therefore it would take longer and he could get his 3 min effort in.
That's the only time it's made sense to me.
My winter setup is heavier, but because I'm using my bombproof parts that will stand up to the snow, mag chloride, mud, etc. It adds 2 lbs, which really doesn't make much difference.
I would argue that lighter is better. If you need more work, pedal harder. By using a light and fast bike, you will keep your handling skills tuned (by riding faster), be better trained to maintain momentum at higher speeds, and be training on a machine that is quite similar to the one you plan to be slaying the race track with. Specificity!
Thats just for the sake of a counter arguement. My training bike is the same geometry, but with a little more stout wheels and tires, and a softer seat :)
I train with a 20 pound weight vest on the road, and sometimes in the woods although it makes bike handling kind of difficult. I use it most in the training rides leading up to a race, especially the last one. That way when I hit the starting line its like losing 20 pounds, and I can ride way faster, and burn way less. Maybe its just mental, but it seems to help me
I like using my heavier MTB bike to get road miles during the winter because:
-Since I go slower at any given effort level, I stay warmer. Less wind chill.
-The bigger tires are safer, for ice patches and such
-Saves the wear and tear on my good equipment
And as a side effect
-don't have to ride so far to the get the same work (KJ's) in
Once the roads clear and the weather's warmer, I go back to the 15 pound road bike (I race mostly crits.........specificity principle). If I want more load, I just increase the pedal RPM, torque (i.e. higher gear), or both.
Buying equipment to strictly get more resistance (by adding weight or rolling resistance), is a waste of money.............unless it is related to one of the above primary reasons.......IMO.
Also, if I brought an MTB to a road group ride......I'll be off the back in about 5 minutes. It all depends who you ride with. ( I usually ride with much younger Roadie Cat 3's).
Correct me if I am wrong, but if you put forth the same effort on both bikes (heavier and lighter), would the only difference result in different speeds?
Seems like you get the same benefit from the training if you put out the same effort when riding the heavier bike, you get the same workout, but at a slower pace.
If that rationale is sound, when riding the heavier bike you would get the most out of the workout by trying to match the normal speed of the lighter bike......which normally should require more effort.
or you could just push yourself on the lighter bike..??
Why not just ride faster when out training?
No. Just No.
It's really that simple. Aside from the entirely valid special circumstance reasons described by some posters, such as wanting to have same effort but go slower to lessen wind chill, etc.
Just Wanna Ride!
A few really strong road guys I know run a heavy set of wheels with bigger heavier tires in the winter. Works well since you don't have to worry about damaging the wheels or tires with potholes or bad pavement through the winter months.
For mountain bike group rides you'll work harder to stay with a fast group if you add some extra resistance. Pick up a set of heavy tires and just keep the rest of the set up the same. Low budget change since you can pick up some heavy steel bead tires cheap - the burlier the better as you'll get extra resistance out of an aggressive tread. Plus it's fun to ride some big burly tires and aim for the rough stuff. You just might improve your handling skills over the winter too.
I think under the circumstances above adding weight "may" have some merit. Also riding SS with added weight using your normal gearing for a given trail could possibly be of some benefit. I just stay seated on my SS and grind out the hills to give my legs a good workout.
For just riding/training on a geared bike I would just get in the big chainring or use harder than "normal" gearing. Adding weight and shifting to easier gears would accomplish nothing IMO.
1 - 20 of 41 Posts
