So I got my Gravity G29. It came with the rear wheel already assembled. Both disc brake calipers were already attached. So I put in the front wheel, fit it inside the disc brake, and tightened the nut on both sides, one at a time and then alternating until they were really tight. Then I tightened the top allen key slot at the top of the bike where the handlebars go and inserted and tightened the handlebar using the four allen key bolts, going in a circle more or less, until they were tight and handlebar was aligned with front wheel direction. Screwed in the pedals, right pedal going clockwise, etc... I put in the disc brake wire for the front disc brake caliper into the right brake lever. Then I sat on the bike and pushed the pedals a bit. Then I took it back in and ensured wheel nuts were still tight.
There are no shifters or gears, it is SS.
Am I missing anything? I don't want to strip or break it when I ride it.
My only remaining problem is I hear a bit of a metallic hiss when I spin the wheels with the bike upside down. Looks like they may be dragging on the calipers a bit in the front and back. How do I adjust them?
