I thought that the Neo 2.3 had the same size/volume as the RaRa ? If the 2.1 Neo has the same size, how does the 2.3 Neo compare to the RaRa ?Neo 2.1 is same size but more grip Neo 2.3 and Kenda 2.3 will both fit.
^^let all your air out and take another pic^^
My wife's trance with same fork and 2.35 nevegal (which is a bigger tire than the 2.3 neo) cleared the bridge just fine too, but if you let all the air out and roll it you hear and feel it rub the crown/steer-stanchion interface.
Again, like I said fox forks are known for their bottom out resistance, so it's a lot less likely to be an issue, but still the potential is there
