They will only wiggle around if their tension becomes less than zero. When this happens (if it ever happens) you have more to worry about than wiggly spokes.customfab said:Sort of, it's a cruiser tandem. The holes measure at 3.4 mm. I have some of the Sapim Strong spokes on the way but those are only 2.3, leaves a lot of extra room in there that I would like to fill up with something. Those spokes are not big enough to keep from wiggling around in the flange which will lead to premature failure.
My personal experience tells me otherwise. Maybe wiggle is a bad way to put it. Obviously to truly wiggle the spoke must reach zero tension, however if there is no support for the spoke head (like with a hole that is too big) it will cause premature failure at the bend.Mike T. said:They will only wiggle around if their tension becomes less than zero. When this happens (if it ever happens) you have more to worry about than wiggly spokes.
