1 - 6 of 6 Posts
· Tenya Laybacker
I find that I bash my big (44) chainring into things more than I would like. I know if I had great skills I could just hop that rear tire up and never touch the chainring(I'm working on it). I also only use the 44t for the occasional pavement access ,gentle double track or fireroad. I'm sure a 38 x 11 combo would see me through all of my big gear needs. Question, has anyone used a 36t middle ring or a 38tDH as an outer ring? It seems like a smaller ring would hit less and give me all the gears I need ,plus they are not much more exspensive than a bash guard.
· Linoleum Knife
The difference is going to be less than 1/2" of clearance between 38 & 44.
Bash rings will take a lot more abuse, and be a lot cheaper in the long run than replacing a $40 chainring every 3 months...
You could run a 36t or 38t middle ring and a 24t granny ring - with a 11x34 cassette, you should have plenty of gears.
1 - 6 of 6 Posts
