1 - 4 of 4 Posts
On the outside....
or on the inside of the tire? On the outside a little warm water and a little finger nail action. On the inside warm water and a medium stiff bristle brush will get most of it off. However, you'll never get rid of it completely. If you intend to continue to use the tire tubeless I wouldn't clean it off anyway. You'll have to go through the sealing process all over again. If you are going back to a tubed set up, just scrub as much off as you can and let dry completely. What's left won't hurt anything, it's just dried latex.
Good Dirt
For what its worth, Stans recommends using COLD water to clean out the injector so you may want to apply the same principle when cleaning a tire/wheel.
Discussion Starter · #4 ·
Thanks. Yes it's for inside the tire. I'm using them on UST tires but they are drying up after a few months.
1 - 4 of 4 Posts
