I'd be interested in a solution too. I've gone through 2 rotors in less than 3 months due to slight warping.tf5598 said:Have a brand-new rotor that is warped enough to where I can't keep it from rubbing. Getting a replacement, but I'd like to see if I can true this rotor and keep using it....what's the best method for doing this?
Best way? Quickest? Cheapest? Take your pic - I've done 'em every way and wrote the FAQ at the top right.tf5598 said:Have a brand-new rotor that is warped enough to where I can't keep it from rubbing. Getting a replacement, but I'd like to see if I can true this rotor and keep using it....what's the best method for doing this?
Talking about perfectionism - I've used my Morningstar R2OC Tech to get the rotors within three thou. Visually that is perfection but of course it's taking things to the silly extreme as the first time the rotors heat and cool they'll be more warped than three thou. But it becomes somewhat like climbing a mountain "because it's there".Psycho Mike said:Take your time and be a bit of a perfectionist when it comes to truing....it does wonders.
... a small crescent wrench.mtb_biker said:Morningstar Drumstix work really well if you're looking for tools to help true rotors.
That will not work as well. With the drumstix you isolate the problem with the two stabilizer forks, then adjust it with the other tuning fork.pimpbot said:... a small crescent wrench.
