As long as you have enough....
brake line it's a simple swap. Pull the spit clamp swap the levers and reinstall the clamps. There is a small arrow on the clamp, make sure that the arrow is pointing up. Tighten the top bolt to torque so there is no gap, then tigthen the bottom bolt to the same toqure. Check that the bars spin at least a full 180 or as far as your fork or bar will allow without binding the rear brake line. You're good to go. If the front and/or rear line is too short you'll need to install new line. That's the nice thing about the Avids, they're a flip-flop desing and will operate correctly in either position. The only other option is to pull the brake lines and swap them between levers, then bleed the brakes.
Good Dirt
Good Dirt
