1 - 10 of 10 Posts
Come see me after class
the groove/flathead trick will be really difficult on such a small bolt head. i suggest drilling a small hole through the center and using an extractor. you can find them at your local hardware store.
Discussion Starter · #5 ·
thats2odd said:
Best way to deal with a stripper is to tip her!!:thumbsup: All kidding aside I had the same problem on a bolt and the recommendation BigGoofy suggested worked for me.
usually i shove dollar bills down their throat til they stop breathing.... but then they usually kick me out...
btw.. i meant allen head.. and i went and bought a B&H screw remover from wally world... did the trick
if it is the pinch bolt for the cable. (only one I can think of the is remotely connect with the cable). The head is exposed
Just grab it with vice grips, back it out, then buy a replacement. Any large set of pliers should do the trick as well,
1 - 10 of 10 Posts
