spotlust said:
What size tires are you going to be running and in what kind of conditions? If you are going to running 2.1 f and r, then I cannot recommend the Spider enough for dry conditions. My dilemma is just what 2.3 to use although maybe I am making this more complicated than it really is. After all, if I like the Spider then . . .Duh. But of course I have to spend more time thinking about what tires to put on than just riding `em. I just read a review on the Turner site of some guy's first ride on his Spot and he was raving about the Sturdy up front, and I have not heard anything negative about them so far; so definitely leaning in that direction.
good question....
typically, it is real dry conditions in southern calif with hardpack, misc....but lately not the case. However, this year was a fluke so i am buying for dry conditions.
I loved my Geax Sedona (non UST) I ran so the Sturdy does sound appealing. However, it weighs in at about 930grams (2.25 version) which is too much for my needs on this bike, which is why I am hesitant and will probably take a pass.
The Big Jim 2.25 UST sounds and looks great as a front tire. It is under 800 grams and my guess is while it may not be a big 2.25, it should be ok and the tread pattern looks good for a front.
I am also going to try to find out more about the Kenda Kinetics. It is the biggest UST tire Kenda offers and their front tire version tread pattern looks great, but heavy at just about/under 900 grams so that one is more than likely off my list for this bike.
I like the sounds of the spider though too, especially if it is good in the dry.
And while the Nokian NBX 2.3 looks awesome, it is barely under 1000 grams so no thanks.
I have to wait for the rims to become available for my new build anyway so I will have fun doing research in the meantime.
Note that these are not confirmed weights. I am using what I think is the best source but could be off for sure. But regardless, I still think in general, the Spider, Vertical Pro, and Big Jim are the lighter of the bunch in terms of tires larger than 2.1.
Cheers
