I've used the DT kit for a couple years on a 5.1.
If the tires you are running are tubeless ready (tubeless bead) then run the DT Swiss kit, and know it'll runs great. I very much appreciate the bead lock and how it make the bead interface very UST like.
If you are running standard tires, you'll need to do another tubeless method, with the probably usual mix of results.
That said, I did run a standard wire bead on the rear for a year, but it was also a 800g thick tire. I did not have the same luck with a Michelin Dry 2.3, it burped a few times (causing pinches to the tire even)
P
P
