Best Rear Racks
1308 Views 9 Replies 8 Participants Last post by  KThaxton
I'm trying to figure out a good rear rack option for a 2020 specialized Fatboy. Surprisingly they didn't include any attachment points on the alloy version. Any good suggestions out there? The Robert Axle Project extend axle is one way to go but kinda pricey.
1 - 10 of 10 Posts
I use the Blackburn Outpost Fat Rack. You can install it with P-clamps in the absence of dedicated frame mounts.
I like the Topeak fat rack, but I'm pretty sure they stopped making those at some point in the past.
Old Man racks work for some bikes without attachment points.
  • Like
Reactions: 1
Might add a Problem Solver Seatpost Clamp mount to go along with the Robert Axle.
(image stolen from Problem Solver website.)
Axiom has a Streamliner Fatliner, looks to be what you want.
(image stolen from Axiom's web site)
I'm a fan of the Axiom racks. I've been using one on my gravel bike, on and off for a while now. Customer service is great too.
RAP and OMM are the same company now -- right?
Regardless, it's a top notch solution.
Salsa also has the rack lock
I was able to get one recently for my E06 (wanted OMM but was always out of stock). It is a nice rack and will work with the RAP axle with some longer bolts. I got the kit from RAP that included the axle, seatstay braces, etc and did a hybrid.
I used the OMM extenders, trimmed off with a couple of holes drilled for 9/16" U-bolts as I liked that setup better than the Topeak braces. The OMM pucks probably would have worked fine but I wanted something a bit more secure so I made my own.
Tire Bicycle Wheel Land vehicle Bicycle tire
Wheel Tire Fuel tank Vehicle Automotive lighting
Cloud Tire Sky Bicycle Plant
Tire Wheel Bicycle tire Automotive tire Bicycle handlebar
Bicycle Wheel Tire Bicycle wheel Bicycles--Equipment and supplies
Sky Plant Tire Mountain Wheel
It has held up perfectly so far, even over some really rough terrain with a rifle cantilevered off of it.
  • Like
Reactions: 2
I was in the same boat (no attaching points), I went with the OMM, I really like the way it mounts and it is certainly beefy (70 lb rating), but it is on the pricier end. It was the only system I could find that I was positive I could mount up without any mods. The Blackburn may have worked with the RAP axle, but I couldn't be certain without actually testing it.
Bicycle Wheel Tire Bicycles--Equipment and supplies Crankset
I just remembered......a couple months ago, OMM updated their rack, there is now an over-seas made rack and an American made version, you can save some bucks on the over seas made version.
1 - 10 of 10 Posts
