jsgolfer said:
i need to find rings for my bike. any places you have delt with in the past that make quality stuff? also, how do i find out what size/how many teeth ill need? thanks
what's the model #?
for 5-arm--- xt m730 was 110/74 bcd, I believe the m737 model's on (circa '94) were compact (94/58). then the 4 arms came in and are all the same BCD (for xt anyway... xtr had some oddball bcd in there at some pt). # of teeth is stamped on your current rings, if those work for ya, stick with it. your rings maybe stamped with a BCD as well (or if they say something like hyperdrive c, that equals compact.
sheldon's site will tell ya how to measure IIRC.
as for rings, you can find 'em pretty cheap on epay- otherwise I've often gone with closeout rings from places like cambriabike, universal, etc... I find shimano & raceface rings shift best for that era of parts. sometimes you can find new old stock (NOS) cranksets for cheaper than a set of rings.
For longevity, get steel middle & granny rings.
otherwise, ramps & pins aid in shifting, but aren't necessary if you've got decent technique. Also, 9spd rings will work fine with 8spd, so don't worry about that issue.
