Get the Avid metallics, you'll be fine and they last a while
are the "avid metallics" the same thing as "semi-metallics"?Zoke2 said:"Get the Avid metallics, you'll be fine and they last a while"
+1
I also like the EBC Gold pads
EBC Gold. Best power, wear and all weather performance.head said:i recently traded into a set of used BB7's and speed dial levers. these are the first disc brakes i've ever owned. i'd like to start out with fresh pads but i'm having a bit of a tough time figuring out what the ideal replacement pads are for these brakes.
i live in VA and ride all year so they'll see all weather conditions. i don't do any real downhill riding other than riding down the hills that occur on my local trails. in other words i'm not a DH rider, i'm an XC rider. i like modulation. i'm 150lbs. i don't know what other information is relevant but lemme know if you need to know more in order to give me some good advice.
thanks for your help.
Sintered= metallichead said:sintered? ok so add that to my list of pads types that i'm unfamiliar with. so are those different than or the same as semi-metallic?
What about noise?asyluminc said:EBC gold - long lasting, quick bed in time, and improved modulation.
I took a quick look here:slipfitting 2 said:Has anyone ever tried any of the ceramic pads? Ceramic sounds like they would be horribly noisy however they claim to be the quietest pad available.
I thought the EBC Reds were c###. no power, nosiy and no braking in the wet.smilinsteve said:Just checked out the EBC website. The red pads look interesting. High friction organics for downhill. Probably don't squeal, and have good grip, but wear fast. That would be ok with me.
I have no idea, I'm just going by what they say on their web site. But they are organic, which should mean they aren't noisy, and they are supposed to be a higher friction version of there green organic pads, so they should have power. I hear organics do lose power when wet, so that part of what you say makes sense.shiggy said:I thought the EBC Reds were c###. no power, nosiy and no braking in the wet.
My comments are based on personal experience.smilinsteve said:I have no idea, I'm just going by what they say on their web site. But they are organic, which should mean they aren't noisy, and they are supposed to be a higher friction version of there green organic pads, so they should have power. I hear organics do lose power when wet, so that part of what you say makes sense.
