1 - 9 of 9 Posts
I have a set of Hope Mono 4's (200 / 180 sintered pads) and am not quite happy with the stopping power . What material offers better power ? Here is a list of choices from one brake vendor. Thanx :
Compound S: Medium
Containing metal & graphite for long wear. Great for muddy conditions, & a good choice in all conditions. Consistent in the wet.
Compound C: Ceramic Black
These organic ceramic fiber disc brake pads are sintered and carbonized. The ceramic compound insulates the brake system from friction heat up to 400oC. The result is a disc brake pad that will keep working in any weather condition, with low noise & a very long wear time.
Compound D: Ceramic Red
This is the highest density, hardest wearing ceramic compound for the ultimate longest life in any conditions. Triple the lifetime of ordinary resin pads!
Super Moderator
njhcx4xlife said:
They don't sound like EBC since the EBC reds are soft and don't last long which is the opposite of what he is saying.
I wasn't going by color match (there is no gold on his description), I was just making an analogy to the 3 compound offer....
Discussion Starter · #5 ·
No name ebay vendor. I don't think the vendor should entirely matter , the material composition is in question. Maybe the question should be does a hard or soft wearing material offer better stopping power ?
Super Moderator
Yes, I understand... what I mean is that the vendors usually use "super nice descriptions" while the compounds vary little... I wanted to know the vendor so that people might help with actual experiences they have had.
Here's the summary:
Organic pads = less power, more modulation, less noise, shorter life
Metallic/Sintered pads = more power, a bit less modulation, a bit more noise, long life
Discussion Starter · #7 ·
Here's the summary:
If that's the case the Hope sintered are probably offering the best power. I think the Hopes are of high quality but the outright power is marginal.
There isn't a perfect pad.
Generally softer pads (resin) are grippier initially, but loose bite after prolonged braking.
Harder pads, initially may squeel and feel weaker, but they will excel once things get heated up.
It's always a trade off.
Super Moderator
Yeah..the sintered ones should give more bite once the system is warm.... maybe your pads are glazed, you could try sanding and burning them in again... that could help..
1 - 9 of 9 Posts
