1 - 20 of 36 Posts
I'm contemplating an upgrade for my bike, and would like to get a fork that is nice and light, but having the "SPV" or Terralogic technology. Currently I'm running a Manitou SPV fork but would like to go with something that has IS mounting for discs (I'm getting a set of Magura Marta SL's). What is available out there that would fit the bill? How are the first few yrs of Fox forks that had the terralogic or whatever technology?
I'd prefer to find a used fork if I can, simply to go easy on the wallet. Any help, anyone selling a fork that fits my needs, please feel free to email me directly at ljklassen(at)mts(dot)net - replace words in parentheses with symbols, of course.
Thanks for any input.
Discussion Starter · #3 ·
Yes, I do realize that, but that isn't really the issue. I am thinking of switching over to a Fox F80x or something along those lines. I'm just not familiar with the newest forks - are there any other manufacturers making this kind of technology (e.g. Rockshox, Marzocchi), or are they all still using manual lockouts?
If people here tell me the best fork for what I'm looking is the Manitou (in terms of performance and weight), then I'd just get a post-mount caliper and swap it out, then stick with my Manitou. I was hoping to get opinions on this, though.
Well, this this really depends on which fork you have now. We know it's a Manitou, we know it has SPV - c'mon, just a little more. ;) If you say a Skareb then you already know it's light and flexy. If it's a Minute you know it's stiff and heavy(ish).
Do share, as we would be better informed to give you an appropriate reply, especially because this thread is more along the line's of a fork comparison. Might help to include wether it's OEM or aftermarket and also what your riding preferences are. (some people find a Skareb flexy, some don't - depsnds on the type of riding and the rider, too)
Discussion Starter · #5 ·
Sorry, that's a fair question - I'm currently running a Manitou Black Super SPV (I think it is 2004). Does it actually make a difference if it is OEM or not? I'm not sure, but I suspect it may be OEM.
I had previously ridden a Fox F100 RL decreased to 80mm, that's now on my wife's bike. I was thinking the Manitou would be much more efficient for racing, but to tell you the truth I don't know too much about setting up these newer forks for optimal performance, etc.
I'm also getting an RLT cartridge for the Fox, so I may end up putting that back on the bike, but I'd like to know what the newer Fox's are like in terms of both performance and weight (the Terralogic ones, that is).
I also previously had a SID on the bike, but hated that for the flexiness. I like light weight (I've also run AMP's on my HT's in the past, and previously had an AMP B5 that was around or just under 20 lbs) but I really want to go with what will be best in terms of performance for racing. I'm just an amateur, but I like to have fun with it.
Currently I'm riding an '01 Ellsworth Truth with the Black Super SPV, full XTR (including discs and older-style, M952 cranks), Thomson post and stem, SLR saddle, Frog Ti's. Fox ProPedal rear shock (2005, not the RP3 version, though). Cane Creek Team wheels w/ Sapim CXray spokes, tubeless tires.
Any thoughts?
Oh, I'm also planning on hopefully building up a HT again - I miss the feel, but don't want it as my everyday bike - just something to race on fast courses. That's a little further down the line, though.
Thanks for taking the time to look and provide assistance.
Any thoughts?
Okay, that's better.
As far as your Black is concerned it won't make a huge difference in it's performance simply because the SPV assembly will be the same either way (same function). If anything i'd say you could look into upgrading to an '05 assembly (if you do indeed have an '04) as they're more efficient operationally. Otherwise, the Black isn't a bad fork at all.
Terralogic? I really can't help you much there. Lot's of rider's swear by it and other's swear by SPV, so i'll just clam-up at this point. If will add, however, that you have one BIG plus with going the Fox route - PUSH Industries. ;)
Either way you'll have a fork that will be efficient and not weigh a ton. :)
Just for kicks, here's the Manitou SPV set-up guide to help you get your's dialed in better if you haven't already seen it. If you're local to Toronto and need a hand let me know.
http://www.answerproducts.com/images/dynamic/SPV/SPVSETUP2.pdf
Doesntplaywellwithmorons!
Spinner Aeris... Sid weight with basically the best stable-platform damper going right now.
Discussion Starter · #8 ·
Andrew, thanks a lot for the set-up guide, that will be helpful. How are the '05's better in terms of being more efficient? Oh, and I'm in Manitoba, so it would be a little bit of a jaunt to get the help - thanks very much for the offer, though! I'll be visiting your city Feb. 2-5th actually, looking forward to it as I haven't really been there for many yrs (I was there for an overnite last summer in the heatwave, but never got to leave the hotel room).
With a Fox, is there any real difference between the '04's to '06's in terms of rigidity, performance, weight, etc.?
Will one really notice a difference between the '03 Float RL and the newer Terralogics, and if so, is there a big difference when getting to the newer Terralogics?
Finally, DeeEight - thanks for weighing in, I remember getting advice from you years ago (I was previously on this as Big Daddy for yrs, but they never let me register like that when the forums changed for some reason) - is that fork you mention available anywhere (preferrably used - I can't afford $750 US), and is it as flexy as a SID, or better than that? I'm assuming at 1.1kg it won't be stiff like a Fox, but will it compare to a Manitou, or be noodly? I'd sacrifice the weight a little if it meant much better performance (otherwise I'd still be running my carbon F3 or carbon F4 on this bike, you know?) but if it comes close and its accessible, I'd sure like to look at it.
Banned
Spinner Aeris...
i have the Spinner and it is definitely what you are looking for:
-80mm of travel
"spul"-valve which is the best stable-platfrom device in any fork on the market. that's where i completely agree with MBA who rated this as THE best system out there.
-1266g uncut for disc-brakes (no cantibosses) / 1300g for V's (1260g cut to 170mm)
-MUCH stiffer than a SID
the fork will go on my Scale within the next couple of weeks. i just have to wait for the snow to melt to have a head to head comparison with my old and trusty SID WC. i already rode the Aeris in my 2nd bike and it performs great. that's a killer race-fork.no softy, cushy ride though. it has just enough resistance at the beginning of the stroke which hinders it from bobbing around.no tranbsition is felt.just smooth soaking of the bumps.it's just not a sofa like some would like. for me the perfect fork. the smallest stuff gets done by the tires, then the fork starts soaking up...
To add to what nino mentioned, its unlikely to be found used... they've been on the market only 1 year, are HIGHLY sought after by racers and weight weenies alike, and they retail new at about $700US and people have been willing to pay that too.
I love Pisgah
Great....
Your killing me yet again. And why am I just hearing about this fork? The humanity.
Retail appears to be $799.95 US. I'd save 115gms over the Noleen. Ouch. Nice fork for sure. Ti crown even.. Now thats cool. Hmmmm...:) Must...maintain...control...
Duck-lusting at http://www.spinner-usa.com/sf_cc.html at the moment.
fox weight from 04 to 06 - 2005 onwards fox forks use more refined internals. the terralogic forks while very stiff and efficient are heavy compared to other race forks - you're lucky to get a set under 1.6kgs. there are 2005 onwards f80rlt's under 1.5kgs that can be found second hand but they have a manual lockout.
manitou have been evolving their spv assemblies. you have the original spv - the recommended upgrade was to spv evolve which is more efficient. the newest generation of spv is spv snap valve and is on the new R7's. i think my advice would be save a little and get a set of r7 platinums. the 80mm version weighs in just below 1.4kgs and has 30mm stanchions so much stiffer than a sid - a little stiffer than the equally sized marzocchi and almost as good as the fox.
Duckman said:
Great....
Well I've mention the aeris lots of times the past year, hell, Nino even bought one awhile ago. There's been lots of threads about 'em and a full MBA review of it. It had a better damper obviously, and it is a bit lighter, but its not available in a 100mm travel mode, doesn't have any sort of damping adjustment, and its not as stiff as a MegaAir obviously (a Ti crown might be stiffer than an Al one, but we're talking 28.6mm SC7000 stanchions vs 32mm EA70 Stanchions...the alloy properties are so close in stiffness terms that the larger diameter wins out here).
Banned
sweet looking...
Jersey said:
the aeris sounds awesome. too bad its like the ugliest fork ever, it has absolutely no character.
well - i on the other hand think that's a beauty.
i don't want a fancy looking fork. black and solver matches any bike out there while red,green,silver with blue stickers (Fox) sometimes don't match a bike at all.
if you take a closer look at the details you will have to agree that it looks sweet;)
@DeeEight:
stiffness is a term that gets overrated big time lately. all magazines, all manufacturers claim added stiffness, stiffer here, stiffer there...we see outboard bearings on integrated cranks which are super stiff, oversized stems and handlebars....who cares for all that sh!t??? as i say over and over italian sprinter Alessandro Pettacchi wins every sprint in the pro peloton using Campagnolo square bottom brackets...so is he really loosing power with his setup?? i don't believe so. also half the pro field of the tour de France runs Campa with square BBs and no one ever complained yet Shimano and all the others make you believe stiffer is better.
same with the oversize handlebars where they make all the hype about added rigidity...no one ever asked about. in fact, german roadie magazine TOUR now rates all those OS stems and bars as too stiff translating too much irregularities into the upper body. the trend is going back yet manufacturers try to sell new stuff...stiff is good fro those who really demand such parts like all the downhillers,freeriders or really heavy people.
the Aeris is a stiff fork. for sure stiff enough for any xc-abuse. let's just not forget multiple champions still ride the SIDs which we all know aren't stiff but who really cares??
Yes, its called the Talon and already exists and has more options available. Its about a $400 fork and weighs a half pound more or so.
Actually, Spinner is expanding the Aeris lineup. I can't remember the details, but I believe it is going to be called the Aeris Sport and includes an aluminum crown.
who sells them? the talon looks like a really nice fork for cheaper than anyone else for the features... travel adjust, lockout, platform, 3lbs+, $299 msrp...
1 - 20 of 36 Posts
