Best Fork Oil
  • Golden Spectro
    Votes: 15 26.3%
  • Motul Fork Oil Factory Line
    Votes: 4 7.0%
  • Silkolene Fork Oil
    Votes: 5 8.8%
  • Torco RFF
    Votes: 2 3.5%
  • Maxima Racing Fork Fluid
    Votes: 4 7.0%
  • Bel-Ray Fork Oil
    Votes: 6 10.5%
  • Ohlins
    Votes: 6 10.5%
  • Redline Suspension Fluid
    Votes: 4 7.0%
  • Yamalube/Honda/Suzuki Fork Oil
    Votes: 3 5.3%
  • Other
    Votes: 8 14.0%
1 - 20 of 23 Posts
moaaar shimz
Here is a list of common fork/shock oils if you need reference/remember the name.
By best I mean you got the best results: better damping, lower stiction, overall better feel etc. Post another oil if you can't find it on the poll (I could only put 10 up there)
Thank you.
Proud lame eBiker
yeah...after RockOil...the G.S. is my very close second pick. Rock is a bit hard to locate and times, and G.S. is in about every moto shop I've ever gone into.
Elitest thrill junkie
It doesn't F-ing matter, they are all more similer than different. Yes, some of the weights vary from manufacturer to manufacturer, but other than that it doesn't matter.
Banned
I've used BelRay, GS, PJ1, ATF (Dexron, Quaker State Semi-Synth and Mobil 1 Synth), and probably a bunch of others. I know to stay away from Silkolene, but otherwise, like Jayem says, if one can match the weights, it's hard to tell the difference.
I just care that the seals are protected and friction is reduced over running a fork dry from the factory.
...for I am a raindog too
I couldn't agree more-- I use spectro-- as it is what my local moto-cycle shop carries-- but I'd never hunt out a specific brand.
Haven't even heard of half of those brands.... I think it all comes down to maintenance-good maintenance practices with x brand of fork oil will keep your ride feeling nice.
Equal opportunity meanie
There's a big big BIG difference between the low end crap and something super high quality. Redline and Ohlins are by far the best, and so is Pro Circuit. For mine, since I change it often and I'm somewhat cheap on things that are disposable, I just go with the Pro Honda stuff available at any moto shop.
Once again you live up to your forum name
LonesomeCowboyBert said:
You must be bored, its just oil
No doubt.
1 - 20 of 23 Posts
