Just picked up new rig which has 140mm PIKE RCT3 fork.
I am 60KG ready to ride.
Running zero tokens and 60psi.
Definitely not getting full use of the travel. I will drop the pressure a bit but if i go to low I think that will generate other negative consequences with the reduced pressure.
Anyone have thoughts on doing the HC97 conversion from PUSH?
Will this help the situation?
Or chuck the Pike and throw on something else. What is the best fork for light riders in the 140mm-150mm range? I’m running fork on Jamis Portal (130mm rear)
I feel like the standard offerings from Rockshox and Fox do not offer enough adjustment for someone of my weight. Cane creek? DVO? MRP?
Thanks for your input!
