1 - 9 of 9 Posts
:confused: Getting confused with the drivers available.
Help me cut through the crap guys!
Which boost driver (exact model please!) should i use for my proposed single MC-E headlight.
As i have said before have got a 7.2V 7.5aph battery i want to use.
Actually i would like to add a dimmer so a reference option on it (like a buckpuck)
would be good.
Cheers.
Tommo.
I agree that the best boost driver is the maxflex. If you want a simpler driver, go with the Fatman, as its a one (or two) level driver instead of having the multi level option. Its also a few $$ cheaper. Set one up with a pot or switched resistor and you have your dual level boost driver.
Fatman!!
I did the research for my single MCE's, and for the $22, the FATMAN is the standout. It's super tiny, first class quality, and you can overdrive the MCE as well. Was my clear choice, and will probably continue to be till I make my own boost driver, or the price goes up a bunch.
1 - 9 of 9 Posts
