I agree that an 888 or 66 would be too much, though I'd want somthing a little taller than a Pike. A guy I ride with has a Reign with a Nixon, and it feels a bit steeper than I'd like.XSL_WiLL said:888 is excessive for the reign. 66 may be a bit much too. Pike and Z1 are good choices if you like to go up AND down.
If I remember correctly, the Nixons are fairly short a-c for a fork of their travel. The Reign has been spec'd with everythign from a Nixon to a 36. I'd run a 36 on it if I was to get one. 5" would definatly be too short.todd_freeride said:well, if you dont like the nixon, then you might want more than 6" because nixons have 145mm. the z.1 is a good choice though. I couldent imagine a reign with over 5" though, thats just madness. but the travis single is one sick fork. manitou shermans can be had for really cheap.
I've run a 03 firefly 130mm and a 05 flick+ 150mm and while I really liked them, my 06 66SL is a much stiffer and burlier fork. The RC2 damping feels better to me than the TPC+, but the TPC+ isn't too shabby either. the 05 firefly probably uses spv so it's a whole different beast.chibow said:I BOught a 2005 Many Firefly on ebay brand new for 250...150mm of travel. How do you think that compares to the 66?
you're probably right. because I have a 130mm splice, and it rides like a 100mm travel fork. also my 90mm stance static, is a really small fork (best fork ever though lol)Hardtails Are Better said:If I remember correctly, the Nixons are fairly short a-c for a fork of their travel. The Reign has been spec'd with everythign from a Nixon to a 36. I'd run a 36 on it if I was to get one. 5" would definatly be too short.
