61 - 73 of 73 Posts
viva la v-brakes!
Do you have a specific question about them?
Just curious if they have held up. I know Dynema is tough stuff, but it just feels like a fiber is going to suffer abrasion over time. Are you still using them?
This place needs an enema
Discussion Starter #62
Of the few dozen sets of these I've built, I've had very few reports of issues. The following are the ones that come to mind, and all were on different wheelsets.
-One Sapim nipple came loose on a customer's wheel and had to be replaced. Oddly, the replacement nip came loose also. Used a DT Prolock and that solved it. I've been using DT Prolock Hex nips with Berd's ever since, with no reported issues.
-One spoke broke on the metal threaded insert. Berd sent out a replacement.
-One of the loop inserts pulled/worked itself out, so that spoke lost all tension. It was still serviceable tho -- worked an awl through the loop to open it up, slipped in a new insert, and tensioned it back down.
That's all I can think of.
I have two sets of Berd wheels now. May build a third for my bikepacking rig this spring. I love the compliant ride.
ACHOO
I think this was asked very early on: do the white Berd spokes get visibly dirty? Also curious if they offer different colors.
Formerly of Kent
I have 2 sets of Berd spokes. One set is on my bike that gets ridden hard and sent on the regular (not that I'm a great rider or anything) and the other set is on my wife's bike and she can't offer any input or wear experience.
Mine have held up fantastically for a long time now, however as I push harder and harder I really do notice the flex in the rear wheel. The rear rim is a heavy duty DH layup CarbonFan rim that should be quite stiff on it's own.
Basically when traction and loads are very high (drop leading into a 40' G-out yesterday for example) my rear wheel flexes to such an extent that I have to stop and make certain that my rear tire isn't flat nor that my rear axle hasn't came loose. It's not really a big deal I guess but it makes me pause and does feel weird.
This sensation has probably happened to me a total of 30-50x in the 18 months or so that I've had these rims, in the past it was very brief, maybe 1 second. This last time it felt loose for like 3-5 seconds, long enough for me to pull over and check the wheel.
Maybe my rear wheel needs to be tensioned?
For trail or XC riding, I'd only purchase Berds. For a light rider, also only Berds.
However for a larger rider (I'm 182#s) doing DH bike park type things I'd either recommend normal spokes, or possibly 36 Berd spoke count in the rear.
Sent from my SM-G892A using Tapatalk
Are you sure the tension is correct?
Sent from my moto g(6) forge using Tapatalk
My rear wheel has remained very straight and only been lightly trued 3x I think.
Not sure I have anyone around here I'd trust to tension a Berd wheel.
How would I proceed?
Discussion Starter #69
Find a shop with a tensiometer and a mechanic that knows how to use it. Ask your riding partners -- they might know of someone.
In the meantime, just squeeze pairs of opposing spokes on all of your wheels to get a baseline. To get the ride characteristics you've described you'll probably be able to feel how loose they are with your bare hands.
Thinking your on to something. When I squeeze the rear spokes compared to my front the rear Berd's seem looser. Will work on this and report back.
61 - 73 of 73 Posts
